Nacra 5.2 shroud lengths
Hi,
I was wondering if anybody could give me the shroud measurments for a Nacra 5.2 mid 80's? everything is bottomed out but the rig is still looser then it should be. the stays are fairly new so before ordering new ones I would like to check that the ones we have are right/wrong length.
There is a lot more to consider than just the shroud length.
Does the mast have a radical rake, most nacra's carry the stick pretty straight up (unlike the Hobie 16's.
Has anyone added any shackles to the bridal wires, forestay etc. or a longer than usual forestay adjuster.
I have help many sailors correct these kinds of problems and what I find most often is that someone has just added shackles, adjusters and the like where ever they wanted without realizing the results. This weekend a P-16 sailed up on our beach and there was a 6 hole adjuster at the bridal wires and Prindle 16's just us a shackle from the bridal wires to the end of the forestay tubular adjuster. He added approx 6-7 inches to his forestay and it was loose as a goose.
if you compare pics of the new mast base, captive for raising, and the old base, not captive, you will see that the new, thicker dolphin striker post lifts the mast a few inches higher
presumably as the old base limited mast rake
it's possible the shrouds were made a few inches longer at that time to to make up for the taller mast ball
1982 nacra 5.2
2009 weta
Okay, here is the answer to the question: Nacra 5.2 Shroud length: 20'-4".
Depending on where you measure - you will come up a measurement close to this. Recognize that you have over 3" of adjustment.
Boat: 1982 Nacra 5.2 with the old ball setup.
I don't see that as an issue, since Nacra didn't offer upgraded shrouds for the boats with the new ball system.
Some of the experts believe that mast rakes does de-power the boat. I agree. My rake is where the mast tip is just behind the access port.
someguyinohio
"Winners sail their own race"
'82 Nacra 5.2
"My rake is where the mast tip is just behind the access port." - using the rear of the access port as A VERTICAL SIGHT LINE - it matches up with the mast tip. I don't run a lot of mast rake here, we have really gusty shifty winds.
someguyinohio
'82 Nacra 5.2
