Nacra 5.2 End Caps
Technical Help
3
Posts
3
Users
0
Reactions
2,182
Views
So I want to replace the end caps on the N5.2 but since the cost of replacements from Murrays is through the roof, that’s if you can even find them, I decided to make my own. I was going to follow the path that Nacraman57 took, he made very good looking white cap, but ended up with a different design. I found black 3” PVC pipe cap at the HD which has a very think side wall, so I set up a router table to take off just enough material so the cut down piece fits into the beam just perfect. I think I like the way these fit better the factory ones I have.
I posted the setup and end result in the tech section but if you don’t have a router table and would like a set let me know.
http://www.thebeachcats.com/pictures/?g2_itemId=108920
ohmsj
Posted : June 6, 2014 3:38 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
