Nacra 5.0 Jib Battens
I added roller furling to my Nacra 5.0 several years ago and the small jib battens do not furl well; they end up poking a hole in the batten pocket. The jib is at my local sailmaker's shop getting a new zipper. Has anyone moved the jib battens so they are parallel to the forestay? Does it perform well? Any advice on the batten length, placement, thickness, taper, etc would be greatly appreciated.
Thanks, Eric
Eric
Trac 16
Schurr Sails just made a set of sails for my NACRA 500 with a furling jib and it has 3 vertical battens. Sails great and rolls up nice and tight. Only thing I found was you can't roll the jib up when not in use for storage so I am in the process of sending them the jib to make the 3 battens removable. Just a suggestion.
Both our legacy Nacras have Harken furling, & as you noted, it furls like sh*t with the factory batten.
Disregard ideas about making the batten vertical, do as you’re thinking, parallel to the forestry.
You probably have discovered that the job flogs without those two short horizontal battens, so you need to duplicate the support they give.
Placing them parallel to the forestry is close to a 45* angle, so make them almost twice as long as factory & you achieve the same effect.
I just placed them in the same spot as originals, works fine.
https://www.thebeachcats.com/pictures?g2_itemId=88333&g2_GALLERYSID=a2ec349bf93162f3afc9edd73b2375a0
Edited by Edchris177 on May 30, 2018 - 08:02 PM.
