Mast Rotation Control Arm for NACRA 5.8?
My 1986 5.8 has a mast rotation problem. Her mast slaps around when her sails are off her and the wind picks up. I replaced the Mast Ball and this didn't help. Should I replace the Shrouds since they have probably stretched? What about adding a Mast Rotation Control bracket? I had one on my 1983 5.2, but my 5.8 is Boom-less.
If I do add a Mast Rotation Control Arm, how should I rig it? Anybody out there have any experience with a Sloppy Mast? I know, this is kind of a personal question, but I just gotta know.
If it's flopping about when the sails are off then you don't have enough tension in the rig. Make sure your shrouds are tight, have a friend pull down on a trap wire while you are adjusting each side to get a nice tight rig
But so tight the mast doesn't rotate at all.
1981 Nacra 5.2
Is your 5.8 the same as the 5.7 & 5.0 boomless setups?
They look like this;
The lines are not rigged correctly, it should be an endless line, giving 2:1
I have an extra if you are interested in setting your boat up this way.
Here's the image. (I posted originally using my tablet and did not find a "copy image address" option.)
One thing I forgot to mention is that the working end of the control line is secured in a clam cleat attached to the front beam. You can see a portion of the starboard cleat at the right edge of the photo.
