Mast F18 yr 2005
A carbon fiber I17/F17 mast will not perform well with your F18 sails. Or, at least the leach curve of your sail would not be correct for the mast.
As Yurdle pointed out, the F17 started using an aluminum extrusion in 2006. This is the same extrusion used on the F18 Infusion. To be picky, these would not exactly match the characteristics of the 2002-2005 F18 rig.
Ryan
Nacra 5.8
Is that right? I thought that the curve was set based upon downhaul with the mast extrusions essentially straight. My experience has been with the 5.x seriese boats, but all of those use the exactly the same extrusion just slightly different lengths (except that Nacra did change extrusions in 1984). So in my mind, as long as the extrusion is the same, you should be able to do it. Unless of course they did something different on the racier boats.
Edited by Wolfman on Apr 02, 2012 - 05:54 PM.
1981 Nacra 5.2
the specs on the mast of the 2003 nacra inter 18 that i just sold was:
Mast Length: 29.79 ft (9.08 m)
this was a certified NA-F18 and was a few inches shorter than my 19' nacra 5.8's mast(30'). it seems odd that an F17 mast would be longer than an F18 or a N5.8 mast.
in the 2012 class rules for Inter 17 it states:
'Length of mast is 8.65 m' (28.38 ft.)
here is the link:
http://www.nacrasailing.org/files/docs/1326622169_Class%20Rules%20Nacra%20Inter%2017%20January%202012.pdf?PHPSESSID=bb3a09696eea001c29af55de08556a2b
or search google for: 'inter17 mast length'
j
Edited by arch on Apr 03, 2012 - 07:33 PM.
If anyone needs... I have an Nacra Inter-18 mast conviently separated into 2 15 foot lengths. If someone wants to try a splice. Cut you a good deal.
Also, I can go on a long rant about getting a new mast shipped from Perfomance/Nacra. Let's just say you should be there to accept/reject and it may take multiple tries to get one in good enough condition. Oh and it's still full price.
Agreed, I could give a similar rant. It's a certified PITA.
If you ship a used one, make sure to insure it in excess of it's value.
