Mast drain plug
Here is what I did to the mast base:
Drilled and tapped hole to take a quarter inch screw with an o-ring to seal it. There was about half a gallon of water in there....
edited by: catdan, Jul 25, 2009 - 10:10 PM
Dan
No, it works fine, No problem whatsoever; it is completely out of the way yet accessible. It does not interfere with anything, neither mast rotation nor pins, nor does it come close to the mast base. Maybe the pics do not make it clear, but the pins and step hinge are on the other side. The bolt is in the front.
Dan
Here is another pic with the mast raised. I am not saying it will work with all cats, but it sure seems to do with Prindles. The bolt is far enough in the front to allow a 90 degrees mast rotation without touching the mast base.
Dan
After looking at the pictures it appears that the boat in the photos is a Prindle 18 or at least a Prindle with a mast rotation control device. No stops on the mast base, I do not believe that it work on a Prindle 16 or any other boat with mast stops such as H-16s and others. I, like Andrew said, think that it would be better approx 1 inch up from the base on most cats.
