Jib sail
I'm in need of sails for a supercat17. i read some where there is another boat that has the same sized sails. i have been searching and searching for the what boat it is but i have not been able to find it.
does anyone know which sails are compatible. the sc17's main is a boom less sail but I'm more interested in the jib. i have a tired main for now. it does not have a roller furler.
sorry can't answer the Q and have never seen a supercat of any flavour in the flesh
But, if you do a search for the texel rating spreadsheet, download it and carefully go through the specs, you will find that it has all the sail measurements of all the common cats. so you will be able to work out which cat jib is closest in size to what you need
off the top of my head i would suggest comparing the 17' nacra 5.2 jib, but as an overlapper it may require different jib block placement
Edited by erice on Feb 17, 2011 - 04:53 PM.
1982 nacra 5.2
2009 weta
skarr1 wrote: Bug tussle http://en.wikipedia.org/wiki/Bug_Tussle,_Alabama
Bug Tussle= Bug Tussle Steak House. This is where we use to go to see who could eat the 96 oz. steak. If you finished it with the trimmings (baked potato) it was free. That folks, is a 6 pound slab of beef. The restaurant has since closed but it was a great tradition for many years. You can learn all about the local culture here. Be prepared to LYFAO:
http://goodlitecafe.com/bugtussle_bugle
