Hull cleaning, glue removal
Hi!
Last time I renewed the non-skid strips on my hulls they didn’t adhere well, I was too lazy to properly clean the hull surface after removing the old ones. Now I decided to put eva foam on a larger area, got some with 3M adhesive. The question is how should I clean the glue from the strips that I removed? Thanks!
Posted : July 3, 2022 10:22 am
Andinista wrote: Hi!
Goo Be Gone works very well for adhesive. You can also use acetone.
Posted : July 5, 2022 11:44 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
