How big of a differ...
How big of a difference between 8.5 and (approx.) 10 foot beam on a beachcat?
(@charlescarlis)
So, you know how, if you have a >8.5 foot wide Beachcat we go to extremes to trailer it? Well, mostly; I white-knuckle full width, but that's a different story... Got me to thinking - the 21 foot Supercat and other 20 foot cats are 8.5 feet wide, so how much of a difference does that REALLY make? On a boat such as mine, the conversion would be really easy, and possibly reversible. Of course, there's a whole hell of a lot of design consideration at the outset around one or the other (I get that).
But, given approximately the same sail area, weight, etc., how much speed/performance do you loose with 1 foot less beam?
Posted : May 10, 2021 2:46 am
the wider the beam, the further out your weight can be to counter the force on the sails
Reduce that distance without reducing the forces on your sails would be "exciting"
e.g.
Mystere 5.5 and 6.0 are the same boat except the bows are .5meter longer and the mast is 1' taller on the 6.0
they made an xl version that has 10' beams (either boat). I have sailed many mystere's and can tell you that the wider beams turn the boat into more of a stable cruizing feel vs a very dynamic heel machine
the wider boat loves the big air, but harder to tack in iight air
I think if you used thinner beams your boat would be a much more wild ride in med and heavy air.
New dolphin striker, and standing rigging (at least 5 wires) will be needed.
better off buying a second catamaran 😉
ymmv
Edited by MN3 on May 10, 2021 - 10:47 AM.
Posted : May 10, 2021 4:25 am
(@charlescarlis)
Ha! Better off buying another anyway, but... Actually, we're talking 1 foot; 6 inches off each side and the way the boat collapses, it doesn't impact the dolphin striker, and I think there's enough adjustment at my chain plate and quick releases I could take up the slack, HOWEVER I'd need to do a new trampoline, Drill a second set of holes in the cross beams, etc. to make up for 6 inches of extra boat on each side of a trailer... Don't think it's worth it. Plus, it's so dang predictable now, I can't see risking that for the minimal pay-off. Maybe if I get grief trailering it or something... But, we're in a regular 10-15 knots quite a bit it seems.
Do I still need a second catamaran??? Hopefully...
Posted : May 10, 2021 10:36 am
Scott Finley
(@smfinley)
Chuck,
Maybe try sailing always sitting on the trampoline. That might be similar to a narrow beam. Then sit with you back against the wings, and that would be like being on the wings with a narrower beam. Not exactly the same, but might give a good estimation. That 21SE has so much sail area an 8.5’ beam would make it more “exciting” in gusts I think. Also the hulls rotate a little when collapsed right? So rudder angle might be altered if you just added extra holes in the crossbar.
Hobie 18M in Chicago
Posted : May 11, 2021 12:01 pm
(@charlescarlis)
Hulls don't rotate appreciably, due to geometry of the sockets and cross beams, but I think it's moot. Pretty much already talked myself out of the experiment.
Posted : May 11, 2021 2:03 pm
