hobie 18 beam- hull damage
The fiberglass where the rear hull beam rests on -bolts to the hull continues to break off small pieces of the outter layer of the fiberglass. It seems to be making point contact and not an even distributed contact. I repaired it once with quality epoxy but that also chipped off. I'm thinking of pouring the whole seating area with epoxy while trying not to get the epoxy on the hull bolts.
Has anyone else seen this problem, how do you repair it?
Posted : March 4, 2009 12:55 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
