Hobie 18 #1264 shroud extender kit help
Any one familiar with how the extender cable attaches to the shroud in order to capture it when the shroud pin is pulled? Link to the kit.
http://www.mariner-sails.com/partdetail.asp?id=23365
H18m
p16
Venture15
It attaches to the shroud and to the chain plate and extends the shroud so after you flop and engage it the above water shroud is longer and the above water hull is leveraged past 90 degrees and over center so as to increase angle so it is easier and requires less force to start the boat to right it self. Problems.. 1.. got to secure the mast at the base as the rigging is much looser due to the extra length of the shroud extender and the mast can slip off the ball. 2.. have to get the extended shroud leeward after righting to be able to re-attach the original shroud connection and take the slack out of the rigging and tighten up as originaly set up... Got Crew? Tough to do one-up. I know.. Hal
I understand the theory and how it all works except how it attaches and captures the shroud when the
pin is pulled. The H18 shrouds have a small crimped fitting on the end of the shroud rather than a loop which could be captured by the shackle. I have this kit and most likely won't use it, But I want to know how it works.
H18m
p16
Venture15
That kit is a very bad idea on any non-captive ball systems like the Hobie 18 and older Nacras. The Hobie 14s and 16s can use this system if you tie the mast to the front beam, but it is still sketchy. What it does is release tension on the rig and that tension is what is holding your mast to the ball. The 18 doesn't have much overlap(?) in that the ball doesn't sit very far into the cup of the mast base. The hinge isn't strong enough to support the mast in that kind of condition.
This sytem works extremely well on my Supercat since it has a very large captive ball.
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
I totally understand the system and the implications of using it on a non captive mast. The only time
that I would pull the pin is if it meant the difference between righting and floating around all night. The
only thing that I am looking for with this thread is how the cable is attached to the shroud so it catches it
when the pin is pulled.
H18m
p16
Venture15
Here you go.
http://www.hobiecat.com/forums/viewtopic.php?f=15&t=24122&hilit=shroud+extenders
Edited by car_guy on Jul 28, 2012 - 08:43 AM.
I found that same picture, but the shroud end on an H18 is a small flat piece called a marine eye and would take a tiny shackle to capture it.
Edited by pknapp66 on Jul 28, 2012 - 08:52 AM.
H18m
p16
Venture15
