Hobie 17 side stay/base pulled out of hull
Hello everyone,
Just needing some help with the starboard stay/base that pulled out of the hull. Is this a fatal injury or can it be repaired? Any idea on cost either to replace or fix? The rear wing sleeve is leeking a bit on the same hull. I think I have an idea of how to fix the sleeve. Any help would be appreciated.
(spacecoast Fl.)
Posted : May 6, 2008 6:38 am
Is this what you're talking about? http://www.hobiecat.com/community/viewtopic.php?t=9293
If so, you might be able to use a drill and an easy out to remove the rest of the stud.
Good Luck
Posted : May 7, 2008 12:13 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
