Hobie 16 Super Jib Battens - Installation
I have the original jib on my 1984 Hobie 16. The battens were hinged, one hinge broke, and I couldn't find replacement hinges. So, I bought a set of Super Battens to replace them. The original battens were tied, but these just have blunt capped ends. How do I install Super Battens properly? π
Posted : June 14, 2014 1:07 pm
What i did with mine is drill you two small holes, about 1/8" diameter ( just large enough to get the string through ) about a inch apart towards the end of the batten that's sticking out with the white cap, then lace them as you would a regular batten and tie off. You don't have to get them super super tight, just snug where there's no chance they'll fall out. They work great btw!!
Posted : June 15, 2014 5:36 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
