Hobie 14 (73 model)...
Hobie 14 (73 model) Raising the Mast Without Hinge
(@damonadmin)
Admin
I think the current model Hobie 14's have a hinge at the mast base to lever the mast up. But on my 1973 there are no holes or sign of such a thing.
Looking at the old assembly manual it looks like I'm supposed to just pick the mast straight up and set it on the mast step.
The manual says to connect only the side shrouds, then have "your assistant" connect the forestay. It occurred to me that it might be possible to connect the forestay while the mast was sitting on the ground, then pick it straight up like the picture and set it on the step, all done.
Sound like a disaster? Need the Hobie 14 folks input.
Posted : June 13, 2013 12:50 pm
(@nacra55)
Damon, I've actually done this on a 16 with a broken mast base, no way to connect the step link. Make sure you have the shrouds and forstay attached but loose.
Ron Beliech
Nacra F-18
Brandon, MS
Posted : June 13, 2013 2:05 pm
(@damonadmin)
Admin
nacra55 wrote: Damon, I've actually done this on a 16 with a broken mast base, no way to connect the step link. Make sure you have the shrouds and forstay attached but loose.
So go ahead and attach the forestay, maybe move the shrouds up a few holes to get some slack? The Hobie 14 mast is pretty light so seems doable. Thanks.
Posted : June 13, 2013 2:11 pm
(@nacra55)
Yes, you need slack. It took 2 of us to do the 16 mast but you should be able to do a 14 solo.
Ron Beliech
Nacra F-18
Brandon, MS
Posted : June 13, 2013 3:12 pm
popeyez7
(@popeyez7)
~~~~ I had one like that... Damon, I'am a short guy... If I can do it,,, well, your tall & big enough to be a ''Gin-pole'' 😆 .. Don't forget the mast bearing ( that white circle thingy) and slack... 😉 You can do it !!! Now get out there and ROCK 😀
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
Posted : June 14, 2013 3:17 am
(@rattlenhum)
That is a daring move for a man that just ground off his daggers....even the Brawny Man! On the other hand, they say bad luck comes in 3s, so you might as well get No. 2 out of the way on the H 14!
Clinton, Mississippi
Posted : June 14, 2013 6:28 am
(@damonadmin)
Admin
rattlenhum wrote: even the Brawny Man!
What?
Posted : June 14, 2013 8:26 am
Peter knapp
(@pknapp66)
The step hinge is like $25 and pretty easy to modify the mast base to accept it. Did this on my 1973 H16.
Instructions come with the hinge.
H18m
p16
Venture15
Posted : June 15, 2013 1:52 pm
