Help needed removing a comp tip
Hey all, I purchased a Hobie 17 mast to replace a broken one, and the person I purchased it from cut the comptip off completely flush with the aluminum extrusion. I've since found that it was also epoxyed quite well when it was last inserted. I've tried just about everything I can think of to remove it, starting with heating the mast with a torch to release the epoxy (that's what Matt Miller at Hobie suggested). I'm now at a point where I'm trying to chisel it out. Any suggestions?
Posted : April 15, 2023 8:57 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
