Help identify this ...
Help identify this roller furling swivel on a Nacra 5.8?
8 Users
(@jollygreen)
https://drive.google.com/file/d/1TcA06zcGaTXUQBqKmW7Y6rHx3PyMkStU/view?usp=drivesdk
Let me know if you have trouble seeing the photo on google drive
It looks like some kind of stay swivel so that the roller furler system can roll up the jib. I can't find that part anywhere, I was thinking about replacing it the next time the mast is down.
Any ideas?
Posted : November 24, 2021 5:41 pm
nak7ben
(@nak7ben)
Best replacement part would be harken part number 164
I’ve never seen the one pictured but had a similar one on a dart 18 and I replaced it with a 164
Hope this helps
Ben saltcitysailing
Posted : November 24, 2021 6:16 pm
(@carbonc)
Harken 1878, it’s like a 164 but with a shackle end.
https://www.harken.com/en/shop/small-boat-furling/standard-furling-swivel-3-mm-luff-wire-shackle/
Edited by carbonc on Nov 25, 2021 - 01:42 AM.
Posted : November 24, 2021 7:40 pm
(@revintage)
As it is quite crowded at the shroud/forestay shackle at the hounds, it might be more elegant to add a short snout of wire (4"?) above the swivel.
Posted : November 24, 2021 11:31 pm
Elias
(@HULLFLYER)
revintage wrote: As it is quite crowded at the shroud/forestay shackle at the hounds, it might be more elegant to add a short snout of wire (4"?) above the swivel.
You forgot to add that if you add a 4 inch pigtail that you will have to shorten the forestay the same amount.
Posted : November 25, 2021 1:53 am
(@carbonc)
How much extra forestay does the 5.8 have? On my 5.5. with a standard jib I don’t think I’d be able to lower the jib halyard that far and still get the jib tensioned.
Posted : November 25, 2021 3:09 am
(@revintage)
Hi carbonc,
Shouldn´t be aproblem even on the 5.5, as it has it´s halyard block ca 10cm under the hounds. Seems to be the same on the 5.8.
Edited by revintage on Nov 25, 2021 - 03:43 PM.
Posted : November 25, 2021 9:30 am
(@jollygreen)
nak7ben wrote: Best replacement part would be harken part number 164
Hope this helps
Ben saltcitysailing
Yea, it seems hard to find, I wanted to find a similar one because it has the halyard block built into it. I guess it's not made anymore
Posted : November 25, 2021 9:34 am
(@revintage)
Jollygreen, can´t see the halyard block, only the forestay pin?
Posted : November 25, 2021 9:42 am
(@jollygreen)
revintage wrote: Jollygreen, can´t see the halyard block, only the forestay pin?
https://drive.google.com/file/d/19-ZkmkNDJBSFptmYNnkeyqi5hoUWANQg/view?usp=drivesdk
Looking closer and at other angles, it looks like they have two pieces of metal that extend from the pin on the swivel, which allows them to connect the fore stay to another pin lower on the metal plates. Looks like they might have a wheel on the top pin to make a block between the plates, then the stay connects between the plates on the bottom with a pin through all three. Does that make sense?
Edited by jollygreen on Nov 25, 2021 - 04:06 PM.
Posted : November 25, 2021 10:03 am
(@revintage)
Probably something added to a standard swivel. Maybe you can move the thingy to the new swivel? It doesn´t look to nice, better take the mast down and inspect it.
Edited by revintage on Nov 25, 2021 - 05:39 PM.
Posted : November 25, 2021 11:30 am
(@jollygreen)
revintage wrote: Probably something added to a standard swivel. Maybe you can move the thingy to the new swivel? It doesn´t look to nice, better take the mast down and inspect it.Edited by revintage on Nov 25, 2021 - 05:39 PM.
Agreed, the plan is to replace it with new parts when I drop the mast to replace the tramp. Just trying to figure out if I can order the same part or if I need to change it out with a slightly different setup
Posted : November 25, 2021 11:56 am
(@carbonc)
Upon inspection my 5.5 uses a Ronstan fork by eye swivel (link below). I measured out the offset from the hounds to jib halyard block and it’s right at 4in now. If a 4 inch section of wire was added before the swivel it would drop the jib halyard down at least an inch when accounting for the shackle.
https://www.ronstan.us/marine5/range.asp?RnID=23 0"> https://www.ronstan.us/marine5/range.asp?RnID=230
Edited by carbonc on Nov 25, 2021 - 08:53 PM.
Posted : November 25, 2021 2:51 pm
(@revintage)
carbonc,
Maybe the the snout-discussion is a nonexisting problem as a shackle or two seems solve it. Your solution with a block below the wire pressing is also to be preferred instead of the amateurish piece on jollygreens swivel.
Important though that the total forestay length including add-ons is correct.
Posted : November 25, 2021 10:08 pm
(@carbonc)
Agreed revintage. The all-in one on jollygreen’s rig does seem crowded and I’m quite surprised the “block wings” don’t contact the shroud pressings when fueling.
Posted : November 26, 2021 6:16 am
(@jollygreen)
Pushed the boat over today and took a look at the swivel setup
https://drive.google.com/file/d/18e394B0Got6oMWw-ArOSZv-l5WQWIu7x/view?usp=drivesdk
It was a bit stuck but some mclube got it swiveling again! Furling jib works great again!
Posted : November 26, 2021 7:17 pm
(@revintage)
Looked better from the correct angle.
When was the last time you replaced your standing rigging 😉 ?
Edited by revintage on Nov 27, 2021 - 08:45 AM.
Posted : November 27, 2021 2:18 am
(@jollygreen)
haha yeah, I ordered a new tramp about 2 weeks ago. When I take the mast down to put the tramp on, I'm going to take all the rigging in and get them to make new ones.
I think tramp is like 13 years old and the rigging is 9 years old
Posted : November 27, 2021 11:52 am
(@carbonc)
That’s a Ronstan RF78A fork by fork swivel. The halyard “block” is just a custom job in the lower pin area of the Ronstan swivel. Looks like the halyard is just riding over the swivel pin between two small chain plates/ tabs of metal plate. Those chainplates connect the swivel pin to the forestay much in the same way the shrouds attach to the hull.
https://www.ronstan.us/marine5/product.asp?ProdNo=RF78A
Edited by carbonc on Nov 28, 2021 - 01:53 AM.
Posted : November 27, 2021 7:47 pm
(@Edchris177)
Captain
Whatever you do, TAPE those ring dings on the swivel.
It is very easy for a line to catch a ring-ding. Once they get pulled out of shape, they can easily come out. Then it’s only a matter of time till the pin comes out & the mast drops.
Posted : November 28, 2021 3:50 am
(@texastuma)
The 164 is an old part number. I use the Harken 207HP. I have used the Harken, Ronstan, Schaefer and a European brands. I have found the standard Small Boat furling gear works well, but struggles under load. That's why I upgraded. I have a sailmaker swage fitting on the top of the forestay and just run the jib halyard through the sailmaker eye and back down the luff. Keep It Simple...
Posted : November 29, 2021 8:24 am
i agree and that is when you really need it to work
Posted : November 29, 2021 9:34 am
(@carbonc)
Scott, what is the primary driver to move from something like the 1880 to the 207HP? I think the 164 only had a max load of 900 or 1000lbs but the new high load swivels (1880) have a rating of 2000lbs which equals the 207HP.
Posted : November 29, 2021 1:42 pm
(@texastuma)
carbonc wrote: Scott, what is the primary driver to move from something like the 1880 to the 207HP? I think the 164 only had a max load of 900 or 1000lbs but the new high load swivels (1880) have a rating of 2000lbs which equals the 207HP.
Mainly set-up. The top pig-tail I built is a sailmaker swage eye on the bow shackle to a swage marine eye that pins in the top of the 207HP. With the top shackle on the 1880, it would be too bulky for my liking. The 207HP is 2.5 oz lighter than the 1880 for those counting weight.
Mainly, to me, it comes to how the swivel sets-up with the forestay. I'm sure some will attach the top of the 1880 directly to the bow shackle. Over the years, I have had the swivel bind up when I did that. That is why I drop the swivel down a foot or so. Plus, it gets the excess weight from the swivel lower.
Posted : November 30, 2021 9:55 am
(@carbonc)
This explains why Scott was discribed to me on the dyke as “the one everyone is always trying to catch”.
Edited by carbonc on Nov 30, 2021 - 06:26 PM.
Posted : November 30, 2021 12:24 pm
