Harken Carbo Ratchamatic
Word to the wise, don't drop a Harken Ratchmatic (spinnaker sheet block) in the sand.... That said, does anyone have an idea of how to fix one after doing so? Mine is stuck in the locked position. Fine when there is a breeze, but not so good in really light stuff. I've tried washing it, boiling it, bouncing it hard on a carpeted floor. Have not taken it apart. Hope this experience helps others avoid perils of letting sand get into sensitive, but otherwise really good equipment...
I know they say when they bind up to soak in almost boiling water (not boiling) to dissolve salt crystals
not sure about sand
They have very good support at Harken
If all else fails, call them and tell them they have locked up - they will probably tell you to send it in for repair / replacement
I had one on my MacGregor 25. When it would get rough (never actually had it lock up) I would put it in a bucket (with a tight sealing lid) of water with a little Dawn dish detergent then put the bucket in my car. After a week or so of soaking and joy riding (agitation) it would be like new after a fresh water rinse to get out the soap.
I was not sure how much broad interest this question would have so I hesitated to ask it. Turns out, you guys gave lots of great advice. I really appreciate it, and will go through the list to try to fix my block. It's back on the boat on the beach now, so I won't have report for another two weeks though. Just got done cleaning and putting together the Harken cams from the mast rotation system. They were full of sand (I bought the boat recently). That was a very satisfying experience, first time doing that. Quick instant gratification with that small project. Thanks!
