H18 Trailer Roller ...
H18 Trailer Roller replacement
9 Users
Evans Family
(@CatSass)
I'd like to replace the rollers on my H18's trailer with something more Cat friendly, maybe 2x6's covered wtih astroturf? Got any better ideas?
TIA
KK
Posted : July 26, 2010 3:06 pm
popeyez7
(@popeyez7)
I did that with mine... 2x10's & 2x4's on the sides so it won't slide off........... I used old carpet I had laying around.... I learned a lesson~~ snow weight on my 17, had the rollers crusch into the hulls. 🙄
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
Posted : July 26, 2010 3:48 pm
Robert Braid
(@turbohobo)
how about PVC, for a H18 you would need 12" - 16" diameter PVC, 2'long, cut length in half, so you have 2 pieces, then split those 2 pieces in half leaving you with 4 half-moon hull cradles. Attach to trailer using lag-bolts, bolts with a shallow concaved head, once attached to trailer cover bolt heads with silicone and then glue carpet to the inside of the PVC, carpet covers bolt heads and allows for sliding surface when wet. No more metal parts to gouge your gel-coat
PVC in different thicknesses can be obtained at your local plumber supply store>
Turbo
On-The-Edge-Of-No-Control
Posted : July 26, 2010 3:58 pm
Rick White mentioned converting his cat trailers into flatbeds using marine grade plywood, covered in carpet. the entire thing was then usable for moving cats, dogs, people, hey and hay.
I always kinda liked that idea
Posted : July 27, 2010 5:50 am
(@Wolfman)
Master Chief
My trailor just has 2x10s covered in outdoor carpetting. There are also 2 rollers at the back to help get the cat on and off, but they are far enough back that the hulls don't sit on the rollers after the cat is loaded on.
D.
1981 Nacra 5.2
Posted : July 27, 2010 6:08 am
David
(@sailinagin)
Found some good threads in the Hobie forum that "Idahosailer" posted on the PVC idea. He even heated the PVC in his oven (slowly and at I think about 210F) to soften them and then put them on the upside down hull to form fit. Covered in indoor/outdoor carpet.
I tried to find 10" PVC with no luck at local stores. Only option was to buy a 20' piece for a lot of cash. Just decided to buy the trailer cradles from Hobie for $170. Use these on front and rollers in the rear.
David
'84 Hobie 18 SE
Posted : July 27, 2010 8:13 am
presto13031
(@presto13031)
Call plumbers around your area... i got 4 feet of 10" FREE 😎
edited by: presto99, Jul 29, 2010 - 05:15 PM
Posted : July 29, 2010 6:14 am
(@damonadmin)
Admin
CatSass wrote: I'd like to replace the rollers on my H18's trailer with something more Cat friendly, maybe 2x6's covered wtih astroturf? Got any better ideas?
TIA
KK
Actually with a Hobie 18 even the single rollers are not a problem, unless you are planning on allowing snow to acumulate!
But upgrading your single rollers to doubles will nicely spread the load and also make loading unloading easier.
Here is a pic of mine, I have them front and back.
Posted : July 29, 2010 1:31 pm
(@p-m)
The trailer to my red boat had the full length carpet covered 2x10's. I loved that trailer. It also had full length 2x4's for guides. Sailors were always sitting on them as they make a perfect park bench at the regattas when the boat is off the trailer.
Now the real beauty . . . you did not tie the boat down. just limiter straps to prevent forward/aft movement.
Posted : July 30, 2010 7:08 pm
Evans Family
(@CatSass)
Hi All
Thanks for the info. I like the idea of double rollers, are they from the trailer company? (I haven't a clue who made my trailer, there aren't any stickers as far as I can see).No problem with snow accumulation here in Tallawhacky.
There is some "repaired" PO damage to one of the hulls right above the rollers, so I want to do something. I'm leaning toward the 2x8 or 10 with carpet idea so far. Pics would be great!
KK
Posted : July 31, 2010 3:10 am
Evans Family
(@CatSass)
Quicke Update.. It is a MagicTrail by MagicTilt, I had to crawl under the damn thing to provide y'all with that info, hope you appreciate my effort. Gonna try and find the double rollers to see how much they cost.
KK
Posted : July 31, 2010 3:34 am
