H18 Cunningham Grommet Corroded and fell out... leaving hole in sail
Technical Help
7
Posts
3
Users
0
Reactions
2,131
Views
This will solve the issue.
http://www.murrays.com/01-1016.html
Or take it to a sailmaker to have a new grommet put in.
1981 Nacra 5.2
Posted : June 10, 2015 6:09 pm
f you put significant down haul on your sail you may find that a normal spur grommet won't hold up for long. My preference would be a riveted plate or a reinforced heavy duty steel grommet that a sailmaker can put in.
I used two 2" by 1/8" thick tsteel washers, drilled holes and rivited both together over hole that was left. It was really tricky getting it together to rivet. I had to use some welding plyers / vice grips to hold it tight to compress everything so that the rivets would set properly. A temporary patch till sail is retired.
Posted : June 11, 2015 6:23 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
