Flaco,
You may try disconnectng the bridle wires at the bow tangs instead of the using the furler adjuster plate. I have the same issue - while my son holds the mast I will invariably drop the pin. Its cumbersome and I am 6'3". I have to rest a bridle wire on my shoulder but I dont see that working for your 5' ft frame wife. You can also do like MN3 says - "loosen 1 side stay many holes". I do this now and it is a time saver as well.
While there are 2 bridle wires to attach they are lower to the ground and by disconneting the bridle wires you are not stressing the wires while being trailored.
Edited by sailinagin on May 20, 2011 - 09:52 AM.
Posted : May 20, 2011 2:50 am
