Gooseneck Clevis Pi...
Gooseneck Clevis Pin
yurdle
(@yurdle)
Hi
Where can I find a replacement clevis pin for the gooseneck on my Prindle 18? Its 1/4" x 1-1/2", which I believe is also the same for all prindles.
Thanks for any advice,
SR
Rob
Nacra 5.2
OKC, OK
Posted : November 24, 2007 4:37 pm
(@damonadmin)
Admin
Depends on where you are located. That's a pretty common item, should be available at any marine store, or catamaran dealer. Fill out your profile (click the profile link in the main menu) and folks can help you better.
Posted : November 25, 2007 7:25 am
Brad Stephens
(@Sunjammers.com)
Most dealers should have something that will work, like Damon said, where are you located?
Brad Stephens
Authorized Hobie Cat Dealer
www.isellhobiecats.com
866-sun-jamm
brad@sunjammers.com
Posted : November 25, 2007 1:14 pm
Kirk Newkirk
(@Captainkirk)
Newby
In a bind on any of the Prindle Cats and the Nacras with booms, They all use the box between the boom and attachment point on the mast. A 1 1/2" X 1/4/20 HEX head bolt works fine with a nylock nut. I would normally take one of the pins out and replace it with a bolt to not lose the box.
Kirk Newkirk
Posted : November 26, 2007 12:57 pm
