Getting cement off ...
Getting cement off hulls
Dan
 Dan
(@DanBerger)
Seriously, I am trying to get cement off some Nacra hulls. A friend had a driveway poured and the boat was next to it and the cement guys let cement splash all over the boat. Jerks.
So, it has a bunch of little gobs of cement stuck to the hull. I thought I could just pick them off, but I can't believe how strongly they adhered to the gelcoat! I picked a few small ones off, but some just won't come off and I'm worried about picking little bits of gel coat out if I chip the cement off.
I know Acetone is Ok on gel, but I don't know if it will do the trick. Muratic acid eats at cement, but I fear it will eat the Nacra, too.
I was also thinking about Penetrol and some other penetrating solvent like goof-off or PB Blast.
Any ideas??
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
Posted : July 24, 2014 5:06 am
(@bacho)
I think acid will do the trick. Don't think you need the 50-50 mixture talked about in this link. I want to say I use 25% acid with success.
http://www.thehulltruth.com/boating-forum/234150-muriatic-acid-cleaning-hull.html#b
I don't think any solvent is going to help much.
Edited by bacho on Jul 24, 2014 - 11:35 AM.
Posted : July 24, 2014 5:28 am
Dan
 Dan
(@DanBerger)
I'll try that--someone else suggested CLR for exactly what I'm dealing with.
Dan Berger
Supercat 15
A Cat USA139
Posted : July 24, 2014 6:40 am
wow - that blows - i think the cement company should cover the cost
Posted : July 24, 2014 8:39 am
(@onekiwi)
Maybe pressure wash the hulls the cement should come off
Posted : July 26, 2014 5:42 am
Eric Weller
(@ericweller)
I have used muratic acid in a 2:1 (2 water:1 acid) mixture to remove mineral deposits off my hull with excellent results. Just wear gloves.
Thanks!
Eric Weller
Keep the pointy side up!
Posted : August 2, 2014 6:35 am
