G Cat 5.0 pig tail
pull to pull, my pigtail wires measure 7.5 inches, the pigtail anchors are situated 13.75 inches back from the center beam.
Check album here
http://www.thebeachcats.com/pictures/?g2_itemId=86940
Turbo
On-The-Edge-Of-No-Control
You are most welcome Elias, as a side note to all G-Cat owners, my G-Cat 5.0 was missing drain plugs, I was able to find them at West Marine but you have to order the drain plug with housing........
Part # RF294
My original drain plug housings were still attached to the transome but, the thread on the old housing was a fine thread and the thread on the new drain plugs is a course thread, did not match........so I ordered drain plug & housing x2, removed the old housings and installed new.
Or you can get the chromed version......
Part # RF737
makes you sail faster........ :joint:
Turbo
