G-Cat 5.0 Boom Pin replacement. Check out the pics!
hey everybody. As you know I broke my boom pin on my G-Cat. I have bought a replacement off a different boat and am going to try to make that work. Please take a look at the pics below. As you can see the new shank is pretty long. If it will slide in and out and bang around to much if I install it this way. Any suggestions on how I should do this? Should I bring this to a welder and have him weld it in? Please help!Thank you all 🙂
Posted : July 8, 2011 2:24 am
Put a sleeve around the pin, the sleeve will be between the back of the plate and where the hole is for the pin (through the boom pin). Sorry i do not have a picture as i have reassembled mine a few weeks ago, sorry. The sleeve should allow a little bit of play but not much, just about 1/4".
Posted : July 8, 2011 7:14 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
