Front Beam prebend
(@Edchris177)
Captain
I'm sure I read about pre loading the front beam,on a Nacra 5.7, by adjusting the DS bottom nut.
I know how to do it, by stretching a masons line along the bottom of the beam & measuring displacement at the DT, but how much do you bend it?
I can't find the photo, or am I hallucinating?
Posted : May 4, 2010 2:18 pm
(@p-m)
Ed,
No need for the masons line. Just hand tighten the nut with no bend and then add 3/8" to the threaded rod. So easy a cave man . . .
Posted : May 4, 2010 5:31 pm
(@Edchris177)
Captain
Thanks Philip, I didn't know how critical that setting was, obviously it falls into the 'bout there category.
Posted : May 5, 2010 2:11 am
(@Wolfman)
Master Chief
Note to everyone, don't try to tighten more than that!! I wasn't thinking and did that over the weekend, managed to strip the dolphin striker and the bolt. Then tried to undo it and really made a mess (should have left it where it was). Hey EC you happen to have another one of those kicking around... 🙂
1981 Nacra 5.2
Posted : May 16, 2010 2:10 pm
(@p-m)
A load from the beam didn't cause the DS rod to strip. More likely the compression tube was corroded to the rod. If your boat has the original alum V bar, you might want to look carefully where the attachment bolts it to the beam for galvanic corrosion. Failure can happen here due to age and the results are catastrophic.
Posted : May 16, 2010 3:14 pm
(@Wolfman)
Master Chief
Nope, I stripped it by trying to put too much load on... it was a new rod that I was putting on. 🙂 I had just finished cutting the old rod off (that I bent last year) and was putting the new rod on when I screwed it up. Wish I could claim your reason, but I can't darn it all. $68 plus shipping mistake (yep, I'm a moron).
Now I have one on order from Murray's, hopefully it will get here before next weekend.
Now here's a stupid question, I jarred the compression sleeve loose so it's isn't lined up with the holes. Is there an easy way to realign it?
D.
1981 Nacra 5.2
Posted : May 16, 2010 3:51 pm
(@p-m)
I just tape it to a stick, or batten. Done.
The stripping thing . . . weird. I can collapse/break a beam, break the rod, etc. by over-adjusting the nut. Something ain't right, bro.
Posted : May 16, 2010 4:21 pm
(@Wolfman)
Master Chief
Yeah, might have been a flaw in the threads or a bad batch of stainless. No idea. Suffice to say I'm going to pay more attention this time.
edited by: Wolfman, May 16, 2010 - 10:05 PM
1981 Nacra 5.2
Posted : May 16, 2010 5:05 pm
eragon
(@eragon)
any stainless bolts must have lube (nickel anti seize is best) before putting any tension on them or they will bind up and resist any adjustment - take note all sailers
Posted : May 16, 2010 9:34 pm
erice
(@erice)
when i did the pre-bend on my 5.2 i worked it out to be about 5mm
about half the 3/8" that some have mentioned....
1982 nacra 5.2
2009 weta
Posted : May 17, 2010 1:08 am
(@Wolfman)
Master Chief
That would explain it! That's what I did wrong! Forgot to grease the damn thing, knew it was something simple.
1981 Nacra 5.2
Posted : May 17, 2010 3:34 am
(@Wolfman)
Master Chief
Thank goodness for Murrays Marine! 1 dolphinstriker rod and hardware, 1 day delivery from California to Winnipeg, Manitoba, Canada! Unbelievable! I will be striking dolphins all weekend now. 🙂
1981 Nacra 5.2
Posted : May 18, 2010 1:34 pm
(@Edchris177)
Captain
Sorry Dave, I only made one of 'em. When I chnaged mine, I realized it would be way easier to push a stick through the tube, as I withdrew the rod, in order to prevent dropping it in the beam. I think it would be pretty easy to tape it to a stick, but you would need two people. Your arms are not long enough to manipulate the stick, & look to see if it is lined up.
I don't buy needing lube on the threads. We used a lot of SS bolts/fitting in a mill I worked at many years ago.(West Coast Vancouver Island salt environment)The mill wrights never used anything on them.
I was concerned the threads of one nut might have been compromised, so I replaced them when I changed my rod. As an experiment we double nutted the cut piece of rod, put it in a large vice, then tried to twist the old nut past some bent threads. Using a 5/8 box end wrench, almost 18" long, it took all the torque I could apply before the nut/rod stripped. The nut was actually hot from the friction. I think there was a bad thread on the rod, or some filings got caught in there, or the rod was not straight. Check for trueness by rolling the rod on a glass table top, it will "click" if it isn't true. You shouldn't be able to strip it without applying a good deal of force, that is a pretty heavy duty rod.
Posted : May 18, 2010 2:56 pm
(@Wolfman)
Master Chief
No problems I'm sailing this weekend, that's what counts! I'll probably never know exactly what happened, but live and learn eh.
1981 Nacra 5.2
Posted : May 18, 2010 3:31 pm
eragon
(@eragon)
happy sailing wolfman great pic here
Posted : May 18, 2010 4:15 pm
