"Felix" the (Unknown) Cat
Just bought an old Cat on a trailer. 4m loa 2m beam 7m mast. Dagger boards and 2 part alloy mast. Single main, no jib.
The only ID are 2 small plates with "Felix" on them and a picture of a cat with its tail up!
Pictures at
https://www.thebeachcats.com/pictures?g2_itemId=74509
Anybody got any idea what this is? Its in the UK and all help will be welcomed. 😕
I don't recognize if from the description, but would like to see pictures. Does the sail have a logo?
Please create an album for the boat in the "Unknown Beachcats" album inside "Beachcats Identification" here.
https://www.thebeachcats.com/pictures?g2_itemId=3436&g2_highlightId=74509
Once the pictures are up someone will probably figure it out.
Wow, now that's something really different.
Everyone look at the Felix album here
http://thebeachcats.com/index.php?module=pictures&g2_itemId=74509
The pic from the back looks like two windsurfers bolted together.
Are there any numbers/letters stamped into the transom? They may be faint or nearly painted/gelcoated over.
Number 1 Sails seems to still be in business, try calling/sending pics of the sail with signature, he might still work there.
Number One Sails
New Road
Middlestown
Wakefield
West Yorkshire
WF4 4NS
Tel: 01924-274073
edited by: Edchris177, Jul 06, 2010 - 12:19 AM
That has to be the weirdest looking cat I've ever seen--it should be pretty fast down wind!
I see it has a tramp on it, but does it (can it) open up with telescoping beams? It looks like the mast base actually rotates on the front beam?
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
I have now had a quick look at it and there seem to be a few things missing and it all looks a bit confused.
I telescoped the hulls and the beams do not seem to be fixed. The mast does indeed rotate with the front beam. The beams slide in to a glassed in tube and there appears to be a mounting-pin hole on the top of the fixed tube near the outside edge, on the top. Unfortunately if you pin the front beam the mast is horizontal! Maybe that is just a transport hole for use on the trailer? The rear beam, which the main-sheet mounting fixed centrally, has no fixings at all and just sits in the glassed in fixed tube. This, effectively makes the tramp a structural component and all that is holding the 2 hulls together when sailing! Is this right?
It has a 7 metre, 2 part "Jack Holt" Mast with a fixed track and 3 mounting tags about 2.5 metres up from the base. The boom is just a "push-on" tube with a couple of mounting tags below. Presumably they hold the main-sheet and the one at the front perhaps some form of down-haul/boom-vang? Doesn't appear to be any mounting. There is also no out-haul so I am presuming the sail is loose-footed, battened and perhaps takes the mainsheet directly with the boom just holding shape?
Too wet to get the sail out in the garden so that will be the next stage.
There are a pair of rear-stays that fit to the mast tabs and mount just forward of centre on the hulls and also there is a mount on the tip of each hull, presumably this will need a split stay that runs into a single, with bottle screw adjustment, that then runs to the 3rd front tab on the mast. Got a bit of nylon rope and a pully doing that job, just for now!
Thanks for all the help.
DanBerger wrote: That has to be the weirdest looking cat I've ever seen--it should be pretty fast down wind!
mummp wrote: I would call:
Number One Sails
Phone: 01924 274073
Fax: 01924 274073
Address: New Road, Middlestown, Wakefield, West Yorkshire, WF4 4NS
Good Point Philip!
And ask to speak to someone name
D Greeves
or
D'Greaves
or something like that, he signed your sail.
Then don't forget to come back and report what you find.
That's exactly what I suggested...yesterday:-D
This has a "cat" on the sail that looks like Felix
http://lowprice.ca/topcat_catamaran_sailboat_ottawa_9bza
edited by: Edchris177, Jul 06, 2010 - 11:52 PM
good find EC
more on the canadian topcat here
http://www.iboats.com/Vandestadt_&_McGruer__Topcat__1981/bp/64b159611r1
1982 nacra 5.2
2009 weta
Already tried to contact Number One Sails.
Their phone number does not accept incoming calls!!!? I have faxed them but so far no reply.
Asked a nice lady at the RYA if she can track the sail number.
Hopefully the wind will drop today and allow me to get the sail up for a look. I will then be able to assess what I need to get it sailing.
Karl :-O
I'm not sure we can say for certain that it was built in the UK, though the sail was for sure. It may not be an original sail.
TopCat Europe made a boat that sounds very much like this one in Germany.
In 1975-77 two Germans built a "boat that was simply plugged together", & had dimensions matching this one. They produced 60 from 77-79, then moved hull production to Italy, but kept HQ in Germany.
The idea of asking around at cat dealers with history might be a good bet.
edited by: Edchris177, Jul 08, 2010 - 04:55 PM
Bumping a very old post! I am researching a 'new to me' 1970s Sussex Cob sailing dinghy mfg by the
Pearson Bros. Ltd. Arundel Sussex UK. While researching, I ran across an archived article post from NYT Jan 23, 1970 titled 'British Accents Take Charge of 'Boatyard' on Fourth Floor'. Under the Pearson Bros. Ltd. bullet; PEARSON BROS., LTD. — The Felix catamaran, the Bonito single‐handed racing dinghy and the Bobbin nine‐foot sailing dinghy, all fiberglass cartoppers, are entered. This reference to the Felix Catamaran may be this elusive cat. As there is very limited information on the Pearson Brothers UK, more research will be needed to verify.
BadKitty wrote: Bumping a very old post! I am researching a 'new to me' 1970s Sussex Cob sailing dinghy mfg by the
Thanks for adding that info, you never know who it might help.
