EZ Step for mast wi...
EZ Step for mast with diamonds
(@ctcataman)
Master Chief
I noticed a EZ Stepper 3 with stuff sitting around. From what I read, you either pull on a trap wire, which pulls the front of the mast, sort of upsetting the side stabilizing wires, or pull on a slug in the mast sail track, which twists the mast the other way when winching begins.
I only lifted 5 feet, as I set up under a tree, but the change inside tension makes me worry.
The gin pole and side anchors are done via a strap, but that moves a bit too. That may be a cause too.
I would welcome any hints on raising masts sideways solo.
Posted : July 6, 2019 1:21 am
(@shortyfox)
The EZ stepper is problematic with Nacra. I had a 500 for 10 years and could not come to a solution that satisfied me. I trailered the boat backwards, so when the mast was in position to be raised it was already elevated by the trailer yoke. I kicked around the idea of an extension for the trailer yoke which would allow me to get under the mast before walking it up. The only thing you really need to do is fashion something on the end of the yoke so the mast can sit on there sideways.
Posted : July 6, 2019 11:07 am
(@Wolfman)
Master Chief
I’ve had one for years and have never had an issue. I did install pad eyes near the ends of the front beam and run the stabilizing line up the mast only to the spreader and through the diamonds on 1 side. Really you only need the gin pole to get the mast to vertical then it should hold itself without much tension while you connect the Forestay the biggest ‘trick’ is to make sure the stabilizing lines are all tight before you start raising. Takes a bit of practise.
1981 Nacra 5.2
Posted : July 6, 2019 2:58 pm
(@Wolfman)
Master Chief
1981 Nacra 5.2
Posted : July 6, 2019 3:00 pm
(@Wolfman)
Master Chief
Also here is the manual. https://static.hobiecat.com/linked_images/3156.pdf
1981 Nacra 5.2
Posted : July 6, 2019 3:04 pm
(@ctcataman)
Master Chief
Thanks for link
Posted : July 7, 2019 4:03 am
