Extracting broken s...
Extracting broken screws from rotomolded hull
6 Users
(@motogon)
Hey guys!
I have little problem with "new" to me Hobie Wave. Two screws that holding rudder mounts broken. Any idea how to extract them without damaging hull?
Andrew
Posted : June 27, 2011 10:16 pm
popeyez7
(@popeyez7)
~~ SAWSALL~~ ok, sorry bout that... just being funny!!!! How did that happen??? HMMMMMM ?? I use "Bosch" titanium drill bits. They work the best for me...... drill into it and try a 'easyout'..... that might be yer best bet. Someone else could chime in here...
Andrew ~~~ welcome to the cat club !!!!!!!! :prost:
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
Posted : June 27, 2011 10:48 pm
tami
 tami
(@tami)
Extract with tool as mentioned. If the holes should wallow, then use West Systems' G-Flex to repair. FOLLOW THE DIRECTIONS, INCLUDING THE HEAT/ALCOHOL TREATMENT.
G-Flex is the bomb. I've used it to repair plastic extrusion on a furler for my trimaran.
You don't have to take my word for it
http://www.westsystem.com/ss/michigan-chainsaw-kayak-massacre
Posted : June 28, 2011 12:18 am
(@motogon)
Is there some kind of inserts or those screws just screwed into plastic body? Is heating that area with heatgun may help to extract screws or this is bad idea?
Posted : June 28, 2011 12:31 am
(@motogon)
popeyez7 wrote: How did that happen??? HMMMMMM ??
I dont't know, I bought it like this.
popeyez7 wrote: Andrew ~~~ welcome to the cat club !!!!!!!! :prost:
Thanks!
Posted : June 28, 2011 12:36 am
(@motogon)
As I always say: if something could go wrong, it would. Extractor broken inside of that screw. I guess I have to drill out that bolt completely and try to thread for bigger size bolt. 🙁
Posted : June 30, 2011 12:34 am
(@damonadmin)
Admin
motogon wrote: As I always say: if something could go wrong, it would. Extractor broken inside of that screw. I guess I have to drill out that bolt completely and try to thread for bigger size bolt. 🙁
Sounds like how my repairs usually go. 😡
Is that the port or starboard hull? If it's the starboard and you completely screw it up you could get a brand new one here.
http://www.thebeachcats.com/classifieds/catamaran-parts/p11383-new-hobie-wave-starboard-hull.html
Posted : July 2, 2011 6:13 am
gketterman
(@gketterman)
Newby
A friend of mine who works on power boats had similar problem Get a left handed bit it will back out on its own enough to grab with a vice grip and twist out
Posted : July 2, 2011 2:49 pm
(@Edchris177)
Captain
Get some advice from a good machine shop. The problem you now have is 10 times worse than what you started with.
The easy out snapped because they are brittle, meaning hardened steel, way harder than the screw you were originally trying to back out. It is very difficult, using a hand held drill, to drill the easy out. The bit is going to want to wander off to the softer metal surrounding the easy out.
You might have to remove the entire fitting, then file the stump square & turn it with vice grips.
Those screws that may be corroded in place are generally easier to drill at nearly the full diameter of the screw shank, then run a tap through the hole, cutting new threads through any corrosion. The remains of the old screw will generally come out as you cut.
Posted : July 3, 2011 12:53 am
(@motogon)
I fix it last week: used center punch to break easyout for pieces, drill out bolt completely, and tap new threads. It was bad idea to use easyout. Hobie used aluminum inserts in hulls which is bad design: aluminum + stainless steel + sea water=corrosion. There is no way to extract that old bolts, only possibility is to drill them out completely.
Thank you all for your advises!
Posted : July 5, 2011 12:22 pm
(@Edchris177)
Captain
Good to see you solved the problem, & that it didn't cost a fortune. The Wave is not a Nacra, but they are still lots of fun. I've spent quite few days on them in Antigua & Barbados.
If you don't weight to much, & sail solo, you can get them to fly a hull.
Posted : July 5, 2011 1:49 pm
