double stack trailer
I am getting ready to convert my trailex trailer to a double stack. Looking at images they all seem to have the rear upper rear crossbar noticeably higher than the front. Anyone know why they do this? I had planned on keeping the crossbars low and fairly level, but don't want to overlook something before I start cutting the uprights. Below is an example. Thanks
H18m
p16
Venture15
It's because of the rocker in the hills. As you slide the boat in over the rear cradles you need the extra clearance from the bottom of the hull to the top of the deck.
Be careful about overloading a Trailex trailer, I've seen a lot of bent ones from carrying 2 x N20's, or 1 x N20 and 1 x F18.
It's the fore/aft beams that bend. If you look from the side, the high spot will be over the axle/springs and the front and back will droop down. I've seen more than one break the center beam. The only way to bulletproof it is to double up the center and fore/aft beams.
Many years ago, we had double stacked tandem Nacras from Texas to Florida and back. I just flipped the top boat over and placed foam cushions overlapping the beams. Keeping the aft beams low kept the forward trailered mast sections high enough to clear a Suburban. Worked very well.
