ο‡ͺ
ο…•
οˆ‘
Double side stays o...
Double side stays on hobie 16
(@thartye)
Newby
I just bought my 3rd used hobie 16 and it has 2 side stays per side whereas most others I see have one per side. I am wondering if Hobie did this or it was added by an owner. Can anyone clue me in?
Posted : June 17, 2024 10:37 am
tominpa
(@tominpa)
I'm not aware of any Hobie 16 with more than one stay per side. It is a relatively flexible rig. I don't know of a reason to add a second set of stays. Any apparent damage?
Posted : June 17, 2024 11:00 am
jonathan162
(@jonathan162)
Never seen such a thing. Sounds loopy.
Posted : June 17, 2024 9:40 pm
(@Dogboy)
Definitely not something that would have come from the Hobie factory that way.
Did they add a second tang to the mast and a second anchor point to each hull, or is it just two wires per side connected to the existing mast and hull locations?
Maybe the previous owner did some distance sailing and wanted some added security against dismasting. Either way, I would go ahead and remove the second set of stays.
If you want to prevent dismasting, upgrade the standing rigging to 5/32” diameter (stock is 1/8”), replace your shroud anchor bolts and bow tangs, and check the condition of the rigging frequently (no broken strands, pins and clevis rings in good shape).
Steve M.
Posted : June 18, 2024 7:19 am
robpatt
(@robpatt)
do they keep the rig in proper alignment? if so, remove the hobie set, sail with the retrofit and see what happnes... if everything is still good... put the real hobies back on and keep the others as spare? what you pay for free advice... all options on the table πŸ™‚
H14T, H18SX... Ocean Springs, MS www.osyc.com
Posted : June 26, 2024 10:17 am
