Do you need carry a paddle?
Now that weather is warm there will be more boats around. I'm trying to minimize the amount of tasks dealing with this boat. So far there's the righting pole, cooler bag lashed to the tramp. Do you really need a paddle? How far can you paddle anyway. I don't expect to be sailing when it is calm, although calm could come when it is least expected. Can I leave the paddle at home?
Yes you need a paddle. Preferably 2. Paddling Is surprisingly effective, cats have little draft and resistance so you can make decent progress just sitting on the front beam paddling. Take it from a person who has been stranded a few times when the wind suddenly quit in him, you will be happy you have it. Just get a couple of cheap extending paddles and lash them to the tramp lacing (even underneath the tramp nice and tight) and forget them.
http://www.murrays.com/01-1303.html
http://m.basspro.com/Bass-Pro-Shops-Telescoping-Mini-Paddle/product/52474/
1981 Nacra 5.2
~~~ A PADDLE,,, A PADDLE he says... A good sailor shouldn't need a paddle. Drop & roll up your sails, push em to the side, angle your rudders at 45 degree, and go ''back & forth'' You''ll make it. I did... 3 miles. If you have to change your heading,, ''slowly'' move your rudder to one ''of'' the sides, then ''quickly'' pull or push your ''tiller bar'' for the direction you have to go and 'hold it' and let it turn some. You might have to do it again.
Theres a name for this, I think it's called SKEGGIN or something like that 😕
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
yes carry a paddle.
if a storm cloud pops up close to you it can suck up all the energy (wind) for hours
i added some bungie to the front hull lips on my h18 and stored my paddle up there on the bow - was never in the way, was always available
- sorry popeyez - i couldn't disagree more - like a boyscout, a good mariner is always prepared
I toyed with the idea of a righting pole/ sculing oar pole but went with fiberglass antennae pole instead. So with paddle I have 2 items to attach to boat, the reason I asked if paddle was needed. I do think sculing oar plus some type of oarlock could serve a dual purpose. The cost of long wooden oars are keeping me from doing that option.
I've rigged the boat to towing, so if I'm too far afield when needing a paddle I could always call for possible tow.
So I'll keep towing the paddle...
Edited by goodsailing on May 25, 2015 - 02:19 PM.
very inexpensive telescoping paddle at walmart, they carry other boating supplies usually for much less than west marine eg plugs. now a moment to vent. you must carry/wear life vests, i wear a water ski belt and keep an xtra vest on board besides one on every sailor on board. xtra vest can be used to tie to top of mast to prevent turtle when righting or to throw to mate overboard when i brought this up approx 2 yrs ago there were no comments, however recent news reports indicate the loss of 4 mono hull sailors who neglected to wear life jackets a few weeks ago. i lost a mast over 5 miles offshore in the atlantic the paddle helped me as did the currents, the vest helped save the mast-kept it afloat til i pulled it on board
very inexpensive telescoping paddle at walmart, they carry other boating supplies usually for much less than West Marine eg plugs. now a moment to vent. you must carry/wear life vests, i wear a water ski belt and keep an xtra vest on board besides one on every sailor on board. xtra vest can be used to tie to top of mast to prevent turtle when righting or to throw to mate overboard when i brought this up approx 2 yrs ago there were no comments, however recent news reports indicate the loss of 4 mono hull sailors who neglected to wear life jackets a few weeks ago. i lost a mast over 5 miles offshore in the atlantic the paddle helped me as did the currents, the vest helped save the mast-kept it afloat til i pulled it on board
We know to wear pfd's. But you paddled 5 miles in the open ocean with the mast on the deck. Holly Mackerel. You're my hero.... 😎 I tie an inner tube to the mast top for now not knowing if my mast will sink or not. It has been sealed.
Edited by goodsailing on May 26, 2015 - 08:32 PM.
i dont care for any walmart boating products - they suck
also the collapsible paddle will eventually fail, i recommend a solid one
I have paddled 3 miles with no wind.. not fun but also not a big deal
and btw - coast guard regs REQUIRE every boat to carry 1 pdf per person AND 1 throw-able .... just fyi
Same here in Canada, BUT, those Jurassic Park water ski belts do not constitute a PFD. They have been illegal here for over 30 yrs.
The make finding a body easier, but if you were to crack your noggin in a pitchpole they only ensure that they kkep your butt up, & your head underwater.
+1
Sculling oar/ righting pole I think is the ticket for this type of boat provided you could find a way to attach the oarlock to the rear xbeam without interfearing with the traveler car. This way you'd have a stick for two purposes. Hmmmm You could also use the boat as fishing platform for non windy days without the mast.
I have my sailmaker sew a pocket (10" wide by 6") to the bottom of the tramp, opening facing fwd, that I can slip the blade of the paddle into. It's located back from the front beam the length of the paddle, close to the port hull, so the head of the paddle protrudes forward of the beam about 2", just enough to wrap a bungie around, to secure it in the V formed by the beam and dolphin striker strap/rod, just inboard of the port hull.
Completely out of the way, yet quickly deployed when needed in a hurry, by whipping off the bungie, and sliding it forward. Saved my ass a few times.......
oar, mast, gin pole, righting pole.... spinaker pole that thinking creatively you could eliminate a pole or two.
you don't sail with a gin pole on board, you can carry a righting bag (in a pocket on the tramp), you don't have a spinnaker .... your making things more complicated than just about any other cat sailor i have ever met
just take off the mast, and throw a giant v8 on back and your all set
:prost:
Quote
oar, mast, gin pole, righting pole.... spinaker pole that thinking creatively you could eliminate a pole or two.you don't sail with a gin pole on board, you can carry a righting bag (in a pocket on the tramp), you don't have a spinnaker .... your making things more complicated than just about any other cat sailor i have ever met
I keep a full size paddle with the blade tucked into the rear beam
accessible to me without moving at all
very helpful when stuck in the lea of an island or if i have miss-judged my landing on a beach by a few inches and need a little more propulsion to land
I have a collapsible in a hatch for my crew (if i have any) or another skipper if needed
Edited by MN3 on May 28, 2015 - 09:15 AM.
When I raced lasers in the 70s I and a number of the other sailors carried the following with a tether on it in the event of a capsize
Looks like fin. You mention capsize. How is this used: propulsion or sticking on the daggerboard for leverage to right boat?
Edited by goodsailing on May 28, 2015 - 10:54 AM.
Neubaur, I've seen someone use one. It was a while ago. I think it is a one-handed paddle designed to be dragged through the water front to back. It braces against your arm for the power stroke and folds back for the return. Works only if you are low on the water as you would be on a laser. Modern cat hulls would probably be too high off the water for this to be effective. Not sure though, maybe it could work, but I prefer a Canadian style canoe paddle.
Yes, works exactly as you describe. It is actually called a praddle, used it years ago with a Laser, allows you to paddle with one arm and steer with the other. I carry two standard paddles one under each wing tramp and a bungee cord to hold the tiller straight while paddling.
The topic of this thread is "paddle", figure it out or do a web search
I ought to know, I started the thread. But since you talked about this device in reference to capsizing, you kinda threw me as I had no idea what you were talking about. I never paddled anywhere when I capsized a Laser. ??????? I did do a google search but not even knowing what it was called or used for I gave up after nothing found.
NO need to rail at someone who asks you to clairify your posts. We're not mind readers. Thanks for the additional info you provided to Dennis, in lue of simply stating the same when I asked the question.
Having a great day.
I bought a cheap Walmart extendable handle paddle with a small blade. I hide it stuffed into the centre lacing on the the underside of the tramp on my Nacra 5.5, with a little tie off so it cant move. I used it last weekend, and as someone else stated, paddling a cat from the front beam while someone steers, is surprisingly efficient. We were moving along a decent pace. I was surprised. The paddle seems very well built (made in the USA from memory). Mine is bright orange. Don't think I'll leave home without it.
http://www.walmart.com/ip/Shoreline-Marine-Telescopic-Mini-Paddle/16606474
Edited by sierracat on May 29, 2015 - 04:38 PM.
