deck port stuck
9 Users
(@rungi)
anyone know a trick to open a stuck deck port. i can not open after taking the boat out
there is no damage but it will not turn
Posted : September 30, 2021 3:59 am
(@shortyfox)
There should be a recessed area on the top of the plate (if it's the screw on type), take a piece of wood, put it against the recessed area and tap it with a hammer.
Posted : September 30, 2021 4:41 am
once you get it off, take the lid and clean it in a container (so it is submerged)
use air if possible to spray out the tracks (on the boat) and finish off with a wet rag - get all the sand and grit out - will make opening easier next time
Edited by MN3 on Sep 30, 2021 - 10:53 AM.
Posted : September 30, 2021 4:53 am
Jonathan Grant
(@Jonathan)
Also, when applying pressure to unscrew it, bang the boat with the soft side of your first. Anywhere near the deck port works. But this will, in essence, help as well. Good luck. Sometimes that can be a punk.
Posted : September 30, 2021 5:21 am
(@Dogboy)
If it’s a screw-in plate, you can take a pair of pliers, open them wide, and put the end of each of the handles into each of the recesses of the lid (pliers pointing straight up). This will give you something easy to grip onto to spin the lid free.
Steve M.
Posted : September 30, 2021 6:27 am
(@waiex191)
Here is what I did. Simple tool - piece of wood, a couple of bushings, and a couple of screws.
Posted : September 30, 2021 7:11 am
Andres Chianale
(@Andinista)
waiex191 wrote: Here is what I did. Simple tool - piece of wood, a couple of bushings, and a couple of screws.
I needed more leverage to open a deck port last weekend and thought of this suggestion. Then I looked for something more at hand and this worked perfectly 🙂
Posted : October 12, 2021 12:33 pm
(@waiex191)
Now we need a contest who can find the biggest tool to open a port! If I only had access to an excavator or something.
Posted : October 12, 2021 4:19 pm
(@raisehull)
Posted : October 13, 2021 5:08 am
is there a deck port down there?
Posted : October 13, 2021 7:19 am
(@texastuma)
raisehull wrote:
What the hell is that white stuff? Looks dangerous.....
Posted : October 13, 2021 9:18 am
(@texastuma)
MN3 wrote: once you get it off, take the lid and clean it in a container (so it is submerged)
use air if possible to spray out the tracks (on the boat) and finish off with a wet rag - get all the sand and grit out - will make opening easier next timeEdited by MN3 on Sep 30, 2021 - 10:53 AM.
Good idea... I have been using Sailkote on the lids to help... seems to do ok.
Posted : October 13, 2021 9:23 am
