Decal removeal
Unfortunatley most chemical solutions could potentially remove your gelcoat also.
You can try a hair dryer to soften the adhesive (DON'T USE A HEAT GUN, it could remove your gelcoat) and scrape with a plastic scraper (not metal). Then just remove the adhesive with a scotchbrite pad and detergent.
D.
1981 Nacra 5.2
When I re-did my cats, (and I've done many) either for sale, other people or my own "TOYS".... I used a hair-blower to help soften the glue in front of the razor. Just go slow with a steady push and use a razor thats "NOT" to sharp, and use one with a handle...... Acetone afterwards to get the rest of the glue off, a scrubbie will help first, then a "WHITE" clean rag. Colored rag will or could bleed. Acetone is also good to help take stains out...
Looks like 4 of us has already been there !! Good luck and keep us informed.......
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
i had MUCH decals on my hulls, i mean big stripes, on 30 something year old hulls. they were real brittle and stubborn. the regular "hot" solvents were working but very slow. since i was painting my hulls, i tried a citrus based paint stripper(citrus strip-walmart). painted on a coat waited 20 minutes, painted on another coat waited 15 minutes, all decals and glue came off in whole pieces. cleaned up residew w/ acetone. didn't seem to affect my gelcoat at all(one hull was white,one yellow). the gelcoat under the graphics will be shiney. this may be a last resort thing to try(small, inconspicous spot first). i have photos in my members album titled "prindle 16 hull paint and repair"
edited by: coastrat, Jun 23, 2010 - 07:28 AM
coastrat
I cannot recommend any higher the 3m pinstripe removal wheel. I have taken pinstripes off of 3 cats now. the first two H16s using acetone, heat guns, razor blades, chemicals and brute force. For the H21 I paid $42 for the 3m pinstripe removal wheel.
H16= more hours than I can remember....3hrs per hull, probably more? Plus it was just about falling off anyway.
H21 which had twice as much pin striping width wise and another 5 feet plus overlapping design: 1 hr for entire boat....
All you need is an electric drill (battery will wear out too fast).
Also with the wheel you dont run the risk of damaging the gelcoat, the wheel doesn't get too hot and its basically an eraser.
1988 H21SE spi
~~ Try some of things mentioned above... Acetone, Alchol, ETC....... If that doesn't work try 800-1000 grit wetsandpaper--- do a small spot to see if it works, if not ya might wanna wait and have the sun fade it... sail yer boat around in circles so the sun can get both sides!!! If ya belive that one I'll tell ya another... Good luck!!! π
~~popeyez7~~
~18 Hobie mag~
~2 Kayaks
~ jet-boat 150 hp.
popeyez7 wrote: [snip] if not ya might wanna wait and have the sun fade it... sail yer boat around in circles so the sun can get both sides!!! If ya belive that one I'll tell ya another... Good luck!!! π
HEY I sail in a lake so that might just work π
Thanks.
Live Life...
