Contoured access ports
charlescarlis wrote: Common technique is to bed them into fiberglass/epoxy bead sort of thing. Don't know about contoured access ports, but I've got to think SOMETHING is around that could do that from all the kayaks and things out there.
They used to be available from many sources but seem to have gone away. I know flat ones can even be sealed with silicone etc. I would rather cet the right ones if available.
If I might give you a tip if you install 'flat' ports on a curved hull, just be sure you don't deform the port ring when tightening the screws. If you do, the cover won't screw into the ring properly and you won't get a water-tight seal.
I mixed up some 2-part marine epoxy and set the ring in that. I used painter's tape to outline the ring so the epoxy was only under the ring.
j
