cold one, anyone?
While sailing my Nacra 5.2 last weekend, my teenage son joked about how we could store cold drinks in the boat. I got a chuckle; we always take a small soft-sided cooler tied to the center bar (another vote for the center bar). But then he remarked he was referring about the inspection ports. Upon testing at home, indeed, the inspection ports are large enough for a hand to extract a canned beverage or long-necked bottle from them. Has anyone ever thought about somehow installing a bulkhead of some type inside the hull on either side of the inspection port, leaving a small pace at the bottom of each side to allow melted ice to drain, which could then be drained at the conclusion of the day's activities? I figure if I can install something in each hull, I might be able to store 12 cold beverages in each hull box. Other than the possibility of losing a port cover overboard, are there any concerns I should be aware with this idea?
Eric C.
1980 Nacra 5.2
I tried it on a boat we had up in the NWT years ago. We used a center hull storage on a power boat. The fibreglass was considerably thicker than the skin of a beach cat, so you have to be aware of can edges or bottles bashing around.
Secondly, all that motion wreaks havoc on the beverages, of course the only thing you are carring is bottled water, right:lol:
Thirdly, ice lasts about as long as a snowball in hell. Even in the NWT & cold water, the ice melted quickly, really quickly.
I considered lining the area with scraps of styrofoam SM, the blue stuff they use in buildings. It's pretty dense, will not absorb water even if immersed for months, & it is easily cut . Use a jigssaw with hobby blade to get good edges, a razor knife leaves crooked lines.
It can easily be "glued" together with acoustical sealant, & a small drain hole cut at the low end. I would place thin sheets of that closed cell packing wrap between rows of bottles to prevent breakage due to the pounding effect of waves. This was one of my better ideas that never happened due to talks cheap, works hard!
One weekend, in a bind we did cobble a cooler together from the above materials, & it kept ice as well or better than any store bought cooler. The physics are sound, yu will have to work a bit harder due to the restricted access. Even a segment of SM on the floor of the hull, & a soft sided cooler worked through the port would be way better than just dropping cans in.
Edited by Edchris177 on Jun 28, 2011 - 12:33 PM.
Bottled water.. rrrrrrrriiiiiiiiiight. 🙂 Good idea about the insulation. It could insulate and serve as the bulkhead material. Since I have one of the all glass Nacra's I think I'll be OK. I see this as being one of the most valuable project I have yet undertaken on this old boat. Will post pictures and progress notes as I get going. I'm not sure if this would be class legal, but since I have seen few, if any, 5.2 races, it doesn't cause me too much concern.
Eric C.
1980 Nacra 5.2
Old fishermen trick. Get a mesh bag and enough rope so that it doesn't reach the bottom of the lake. Put beverages in bag and drag it behind you. If you get it down below about 5 ft it will be plenty cold! 😆 Of course there is the downside of dragging your beverages around the lake and getting snagged. But the upside is that if the local constabulary comes out to inspect, the won't find any beverages (or you can cut line and the evidence is gone). I wouldn't actually suggest you do this, but it does work if you are anchored at a nice fishing hole. :banana:
1981 Nacra 5.2
What they need to is make a port within a port. The outer part would be like the regular port. Maybe modified to give as much diameter clearance as possible and still do its job. This hard mounted and seal to the deck. Then an inner port with an built in cat bag similar to the Fat bag except this bag is very insulated. The outside of the bag would need to be durable and able to withstand abrasion from the inside of the hulls. This unit would screw into the first port making a seal that would not allow any water into the hulls even if the entire insulated bag was full of water. This insulated bag would then have it's own lid that can come off or open easily and is attached to it cannot be lost. Even if you open it to crab a drink and somehow capsize while it is open you cannot flood your hull or lose the cap.
You could even have a separate unit that screwed into the same port but instead of a cooler for individual drinks it was an camel-back type bladder with an insulated outer section that you can ice. The straw for the bladder would come up through the secondary lid and clip to the the shroud for easy drinking access. It could even have 2 spouts so skipper and crew don't have to share.
There goes another great invention idea I'll never get paid for but hey build away. I'd sure buy one.
Dustin
Magna, UT
Prindle 18
If you read my Singer Island Sailing Adventure, I mentioned going sailing with Craig on his Super Cat 20, and Craig loves his beer.......cold. What he did was lift the top deck off, glass in a box leaving space underneath for water to drain, lined the box with some kind of insulation, and re-attached the deck. He situated this cooler directly under his port, he would screw the port cover off, pull out the port bag, drop in a load of ice, a quantity of beer, put the bag back in and screw the port on and go sailing, he never ran out of cold beer.
Turbo
Turbo
On-The-Edge-Of-No-Control
