clunc from my hobie 17 hulls
hi all,
i was able to separate both hulls from the beams and now i have the hulls in my garage.
I hear cluncs from both hulls when i flip and roll the hulls.
Can i suspect any styrofoam blocks inside that cause this sound?
If so, is it common? What can i do about it?
//Mats
Posted : January 9, 2017 3:54 am
It is likely the foam blocks inside the hull. They are located behind the centerboard trunks and are there to keep your boat afloat in case you get a hole in the hull.
You could also be hearing the centerboards banging around inside the wells. Either way, it is not a concern.
Edited by Dogboy on Jan 09, 2017 - 11:24 AM.
Steve M.
Posted : January 9, 2017 5:24 am
Forum Information
- 1 Online
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
