Clear coating sanded/tapered battens?
seems like the only two options you have are either epoxy or automotive urethane clear coat. I wouldn't think a UV stabilized acrylic would either work good or last long. But, I got to say, I hate those splinters! I'm guessing you're also referring to the pultruded fiberglass battens, yes? That actually makes a difference as to what sticks or what prep you'll need to do. Too much epoxy and you stiffen the batten, so...
Posted : May 24, 2021 9:38 am
Yea, I was leaning towards a spray able clear coat.
Would need to be very flexible though.
Doesnβt even have to be clear actually.. who cares what color it is. Canβt see em.
Plasti dip? Hmm
Nacra 5.7 fiberglass battens that have a cross section that resembles Saturn.
Posted : May 25, 2021 11:21 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
