Cat Trax -- Trailer...
Cat Trax -- Trailer Holders
8 Users
(@panic_button)
I've read several posts stating that people's trailers have Cat Trax holders, and I've searched for a picture of what they look like with no luck... Can someone post a picture of how they have them mounted to the trailer when traveling? Currently, I just tie mine to the tramp and pray they don't fall off.
Thanks-
Chris
Posted : May 6, 2013 11:43 am
(@PurdueZach)
I would be curious to hear other's responses. I put mine on the top of the hulls on the front or rear. Some people put theirs on the trailer crossbars underneath.
Posted : May 6, 2013 12:25 pm
(@p-m)
This is the best system I have had on any and all my boats. Catrax axle held in place with a trucker's rubber hood latch. Enlarge picture and zoom to bottom. You can see one of the two vertical support post that are part of the trailer's a-frame. Image is in my folder.
Posted : May 6, 2013 1:29 pm
Dustin Finlinson
(@Quarath)
Master Chief
Mine just ride across the top of the hulls as well.
Dustin
Magna, UT
Prindle 18
Posted : May 7, 2013 7:02 am
presto13031
(@presto13031)
I put my setup in the tech photos section. Can take more and better photos upon request
Posted : May 7, 2013 9:07 am
(@coastrat)
Master Chief
i have a sheet of marine plywood on the trailor. i put a cleat on both ends and cleat the cattrax to it...easy!
coastrat
Posted : May 7, 2013 2:55 pm
(@p-m)
That PBR keg better be empty . . .
Posted : May 7, 2013 4:23 pm
(@i20sailor)
Newby
My trailex has 2 vertical posts (about 2 ft tall) on the toung between the front mast support and where the boat box is mounted. Each post has a rubber V-shaped cradle. The distance between the posts locates them just on the outside of the cat trax wheels.
I've had this set-up on 2 trailers and works very well.
Posted : May 8, 2013 1:24 am
(@rattlenhum)
presto13031 wrote: I put my setup in the tech photos section. Can take more and better photos upon request
Bloody brilliant! I'm not sure that I have enough room between the sail box and mast crutch....gonna check on that.
Clinton, Mississippi
Posted : May 8, 2013 6:04 am
(@coastrat)
Master Chief
it was drained in less than 6 hours after hooking it up, it amazing how many friends you have when tap a keg! looking into homebrewing, i have several old kegs around and am looking to put them to use...bulk buying and all that.
coastrat
Posted : May 8, 2013 6:07 am
