Cat Trax Repair and Mod?
I came across a Cat Trax. It is bent outboard of one wheel, tip sag about 5 inches. I was going to get my super cheater bar, a 6 foot DOM tube and straighten it. It will be mostly but not perfect. We have only used home made dollies so this is a big step up. Will a little bend be a performance issue?
I was thinking of modifying it to be used on an 8 foot and a 10 foot beam boat. I would cut off the bend,, reposition cradle to straight tube. Cut in middle, and put an inner or outer telescoping tube that would be pinned into either position. Out would be stronger and heavier obviously. It may depend on material availability.
Any recommendations?
Sounds like you have a plan, you are going to like using "real" cat trax.
If the tube turns out to be too bad to save it can be replaced, it's just an aluminum pipe. The axle pipe is $75 from the Florida Sailcraft.
http://www.floridasailcraft.com/CatAccesories.htm
