Bent Prindle Gudgeon
Those castings do not bend very successfully. I’d get hold of Pete Begle, or Dan Berger, both are reputable vendors on this site.
https://www.thebeachcats.com/classifieds/catamaran-parts-for-sale/p16326-prindle-rudder-castings26amp-3b-rudders.html
I have seen the Prindle rudder casting getting warped from time to time... but never bent... You may want to try heating it up and see if can get it back to the original shape or close to it. At this point you have nothing to lose.. but my recommendation would be to buy a used or new one.. they pop up from time to time on Craigs list pretty cheap
There is a lot of info on the web about bending aluminum castings, and temperature matters. Not too hot but not too cold. I would set it up with a clamp so that I can straighten it a little bit at a time. Rub the casting down with a bar of soap. Hit it with a torch, and when the soap is brown, clamp it down a bit. Don't do it all at once. I am not a metallurgist, and don't know how much you want to bend it, but I might do this over a few weeks. A little heat, a little bend, and then a few beers...repeat. Once you have it where you want, it should not spring back.
mason1114 wrote: What is the procedure to bend a Prindle Gudgeon back to shape. I have one that is bent which causes a significant amount of rudder slop. Is it possible to heat and bend back without breaking/cracking? Anyone ever attempt?
Causing rudder slop infers that the two loops of aluminum that form a slot for the rudder are bent outwards away from the rudder, causing a wider channel towards the aft edge of the rudder. Is this the issue? I had the very same issue on my latest P19 when I first got it. I put a large C clamp on it and compressed it back together. I just snugged it up the first day. Then, I would give the clamp a turn each day over a period of about a week. I was afraid it would explode into pieces at any moment, and found that humming a little tune seemed to work whenever I would tighten the clamp.
In the end, it worked out fine. If I bent it another 1/4 inch or so it would be perfect but just don't want to push my luck.
Bill Mattson
Hobie 16 #58342
Santa Maria, CA
