ο‡ͺ
ο…•
οˆ‘
Beach wheel help
(@optikid)
Hi, i was looking at my beach wheels and the bearings dont look right.
any ideas?
Posted : July 16, 2012 3:51 pm
Dustin Finlinson
(@Quarath)
Master Chief
Get rid of the PVC, that was for the old style you don't need it anymore. You should have 20 delrin rollers inside each hub. All you need is a the flat stainless or nylon washer (mine has both) that sits right against the rim on each side to hold the rollers in place. Give the rollers a spraying with sailkote before you seal em up. If you are converting from old style to new you may need to drill a new hole on one side for the cotter pin to go through as the old holes were wider apart.
Dustin
Magna, UT
Prindle 18
Posted : July 17, 2012 7:22 am
(@optikid)
i bought them like that... and i have a metal washer.
Posted : July 17, 2012 12:10 pm
(@optikid)
do i need the nylon one?
Posted : July 18, 2012 11:49 pm
sailkote is not recommended for bearings.. it will cause sand to stick to em' and leave flat spots
fresh water rinse is suggested
FWIW
Posted : July 19, 2012 12:50 am
Dustin Finlinson
(@Quarath)
Master Chief
I happened to have both the old metal and the new nylon ones when I converted mine so I put the metal against the wheel and the nylon next to it and then cotter pinned it. You probably do not need both.
Dustin
Magna, UT
Prindle 18
Posted : July 19, 2012 7:35 am
Dustin Finlinson
(@Quarath)
Master Chief
FWIW
Didn't know that I kind of treat it like WD40 for the boat. A little here and there helps everything. πŸ˜€ But mostly I apply it to the edge of bolt rope that hits the track most every season.
Edited by Quarath on Jul 19, 2012 - 01:39 PM.
Dustin
Magna, UT
Prindle 18
Posted : July 19, 2012 7:37 am
a swollen boltrope / dented track is a good use for sailkote , so is sparying on a spin so it will snuff better...
Posted : July 20, 2012 1:06 am
(@PurdueZach)
MN3 wrote: a swollen boltrope / dented track is a good use for sailkote , so is sparying on a spin so it will snuff better...
I even used it in a pinch last night to loosen up a stuck lock on my cat box.
Posted : July 20, 2012 3:10 am
