Batten Question for...
Batten Question for Boomless
(@mrvideo)
I have two long battens that came with the G-Cat 5.7 main that fit on the bottom slot.
One is standard (like the others) 1" width and the other is about 2" width.
Which is the preferred Batten width for the bottom batten on this boomless Main?
This is a Supersail standard OEM sail for a 28' mast.
Thanks!
Posted : September 12, 2021 2:41 am
(@jalex)
Not much of an answer to your question but my Supersails 5.7 main has all same size battens, that’s how it came from them
Posted : September 12, 2021 4:57 am
Peter knapp
(@pknapp66)
Not sure if this relates, but the Nacra 6.0 uses a heavier bottom batten in heavy air and is also boomless. With
the large jib in heavy air the main gets back winded and partially inverts. They call this the main sail Hula. The heavier batten is supposed to minimize this.
H18m
p16
Venture15
Posted : September 12, 2021 6:06 am
(@mrvideo)
pknapp66 wrote: Not sure if this relates, but the Nacra 6.0 uses a heavier bottom batten in heavy air and is also boomless.
A heavier batten all the time or just in heavy air? Are they swapping them out?
Posted : September 12, 2021 8:05 am
Peter knapp
(@pknapp66)
When I had my 6.0 we would swap it. Not sure what others are doing but it is sold for heavy air use. I think it
would effect sail shape in lighter air.
H18m
p16
Venture15
Posted : September 12, 2021 9:55 am
(@shortyfox)
I've used them both in a 5.7 and can't tell any difference.
Posted : September 12, 2021 10:51 am
