Asymmetrical helm
(@sandrimr)
Newby
My old Tornado cat has strong weather helm on a starboard tack and strong lee helm on a port tack. Obvisouly some asymmmerty somewhere. Any suggestions on where to look? Using sail trim I have to stall the main on one tack and luff it on the other just to make the helm managable.
Thnaks, Michael
Posted : December 8, 2011 7:28 am
are your rudders on backwards? kidding
perhaps your mast is not over the CE
perhaps your boards are not tucked under the same
perhaps a board or rudder is warped
Posted : December 8, 2011 9:03 am
Dustin Finlinson
(@Quarath)
Master Chief
I have had something similar when one rudder wasn't quite locking down right,
Dustin
Magna, UT
Prindle 18
Posted : December 8, 2011 3:41 pm
(@Edchris177)
Captain
I sailed my 5.7 that way for a year. I put levels on the mast,thinking one shroud was shorter, checked rudders, diagonals etc. I looked for a bent mast, & made sure rudders were the same geometry. I measured the ends of the hulls & found they were not in alignment. I finally pinned it to a front beam that had a slight kink, right near the connection to the starboard hull. This forced one hull into a lean, & pointing off center. I replaced the front beam.
Posted : December 11, 2011 12:59 pm
+1 Edchris177
i was just thinking this weekend, that your beams are not square
Posted : December 12, 2011 1:36 am
(@sandrimr)
Newby
Some good ideas. I'm off to take some measurements.
Thnaks for you help,
Michael
Posted : December 12, 2011 9:09 am
(@klozhald)
Master Chief
Edchris177 wrote: I finally pinned it to a front beam that had a slight kink, right near the connection to the starboard hull. This forced one hull into a lean, & pointing off center.
Nice find.
It wouldn't take much of a kink to give this effect.
sandrimr check the crossbar beds in the hulls for integrity.
A sloppy mount (fiberglass or hardware) would give the same effeect.
Edited by klozhald on Dec 13, 2011 - 08:50 AM.
Posted : December 13, 2011 2:48 am
