Arribastick repair
Technical Help
2
Posts
2
Users
0
Reactions
2,294
Views
The end of the inside has broken off and is now in the outer. Fixing requires taking the clevis end of the inner off and and then sliding the whole thing apart but you say it is apart already.
Re-attach the outer collar, then the outer then the lower cooler.
In short take the small inner apart until the outer can slide off both ends. Put the non clevis end back on, outer on and then the clevis end. HTH, Richard.
Posted : December 9, 2013 1:54 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
