Anybody grease thei...
Anybody grease their jib furlers?
6 Users
(@rondog)
Thinking of rebuilding mine and wondering what type of grease people use in the bearings?
Is silicone grease or Vaseline good options?
Also, is it ok to put a little grease on the teflon washers?
Posted : September 8, 2014 6:29 am
(@damonadmin)
Admin
NO
the rebuild kit comes with new washers and bearings, they are not designed to be lubricated.
Posted : September 8, 2014 6:52 am
almost all lubricants will trap dirt and sand and prevent bearings from rolling... leading to flat spots and worthless bearings.
harken does make a product specifically for their bearings called McLube™ OneDrop™ Ball Bearing Conditioner but (IN MY OPINION) your better off just cleaning your furler(s) with warm/hot fresh water often than needing that sutff there. Keep your furler out of the sand and your fine for years of service
Posted : September 8, 2014 7:22 am
(@rondog)
Ok good advice! Will do!
Thanks guys!
Posted : September 8, 2014 7:44 am
(@sander83)
Also you could use a little handdisch cleaner, this is wat i alway's use on my trefler. It will grease and clean pritty good and wil wash of by just a little water 🙂
Posted : September 11, 2014 7:09 am
i respectfully disagree, it may work short term but it's bad for the bearings for the reasons stated above
Posted : September 11, 2014 10:48 am
Larry Smith
(@lawrencer2003)
I'm in the no lubricant camp for all the reasons mentioned. Anything that holds dirt or sand is bad. Keep it clean and out of the dirt.
Larry Smith
Posted : September 12, 2014 9:03 am
Jim
 Jim
(@911hobie)
Second MN3. I have an H 18 and just keep the furler clean, rinse off after every use and rebuild every couple of years or so as needed. I do use McLube on the upper forestay swivel to help keep it working smooth.
ADDICTION
1989 HOBIE 18SE
HOBIE ALTER SIGNATURE MODEL
Posted : September 14, 2014 12:22 am
