$60 Functioning bea...
$60 Functioning beach wheels for a p16, a how-to
(@anrkii)
I am very much a do it yourselfer, and theres no way Im paying $400 for cat trax! I know they are nice , but I just cant do it.
Anyway, I have built and tested a set that cost only $50 , and all of the parts came from Lowes, and harbor freight tool store.
List:
10ft of 1" emt conduit
10ft of 1 1/4 pvc
10ft of 1" pvc drain pipe (the really thin stuff)
4 1 1/4" pvc caps
2 5/16" eyebolts
1 1/4" hole saw
2ft of 4x4" lumber
2ft of 2x6 lumber
at harbor freight I got the 13" heavy duty tires on sale for $11 each, PN# 37767
(Beer consumption not included in $60 estimate)
start by knocking the bearings out of the wheels and make the bushings for them out of the thin 1" pipe.
the thin pipe rides perfectly on the conduit tubing, but its a tad loose in the wheel, so shore it up with a few wraps of electrical tape.
then (for the p16), cut the tubing 94" long and drill a 5/16 hole through an inch from both ends, these are for the eyebolts.
cut two 8" sections of the 4x4 and 2x6, and screw them together in an "L" like in the picture
holesaw both L pieces all the way through so they fit on the tubing.
Now it all goes together in this order: 1 1/2" long pvc, L cradle block 4 1/2" pvc, wheel, center pvc (64" or so), wheel, 4 1/2 pvc, cradle block, 1 1/2" pvc. You have to holesaw the pvc caps and use them on both sides of the wheel so they have something to butt up against. The eye bolts hold it all together.
cover the wood with a scrap of carpet or rubber, and add a couple of ropes.
I also put a squirt of expanding foam in the pipe ends to help it float.
And thats it, your craptrax are ready to go.
I have no idea how they will work on sand (never seen the stuff) , but on midwestern beaches, aka rocks and dirt they work great. Soft sand would probably need balloonier tires. (is that a word?)
the axle doesnt flex very much under my p16, but heavier boats would need a better axle.
Ill bet you could even add a tee in the center section for a handle, Craptrax deluxe!
Also I added an awesome sticker to my boat to scare new crew while i was at it! 😀
Posted : June 18, 2011 7:22 pm
Robert Braid
(@turbohobo)
that's almost exactly how I made my own beachwheels, except I used metal gas line for my axle, after removing the bearings it fit exactly into the wheel hub, used a swim noodle over the metal to protect the bottom of my hulls, doubled up on the wheels for beach use and used split pins in holes drilled through axle with a large washer butting up against wheel hub to keep everything in place, viola! sturdy set of CrapTrax2.
Turbo
Turbo
On-The-Edge-Of-No-Control
Posted : June 19, 2011 12:08 am
Terry McClure
(@golfdad75)
Yea but for most of us soft sand is THE issue.
Terry
Nacra 5.2
Posted : June 19, 2011 4:58 am
Dustin Finlinson
(@Quarath)
Master Chief
Sand is the reason they use the big ATV tires an account for a fair bit of the cost so if you found a bigger wider tire at a decent price it would help on sand. You need to make an album for this in the tech gallery
Dustin
Magna, UT
Prindle 18
Posted : June 19, 2011 11:18 am
