474 de rigging roblem
If it has the conventional ring on the halyard and hook on the mast you need to rotate the mast in the direction that the hook will catch the ring while raising. To lower you raise the sail above the hook and
then rotate the mast in the opposite direction so the ring misses the hook and comes down. If you have
a mast rotator you need to loosen it so you can rotate the mast to the stops. Having the boat into pointed
into the wind makes this all go a lot easier. If your sail is not traveling free in the mast track that can also
hinder raising it above the hook in order to lower it.
H18m
p16
Venture15
The freestyle has a halyard ring the fits over the top of a hook at the top of the mast. When dropping the main apply downward pressure on the halyard and simultaneously rotate the mast so the the base is pointing at the starboard hull...realease halyard pressure and roatate the mast back to a centered position
Yeah, its fiddly the first couple of times you do it. I actually tie the end of my halyard to the starboard side of the ring so I have the option to pull it out of the way of the hook. One word of warning if you do that, you have to tighten and secure the halyard while sailing or it will flop around, get caught on battens and be generally annoying.
1981 Nacra 5.2
