18 front crossbar bolt stuck need help
Technical Help
2
Posts
2
Users
0
Reactions
2,011
Views
Today I started to install my front crossbar support kit. One of the inside front crossbar bolts is not going to come
out and will most likely break. I see in the catalog that there is a square nut listed for this bolt. My question is what is
involved in replacing this nut? I can see some rivets close to where the bolt enters the crossbar. Thanks.
Edited by pknapp66 on May 10, 2012 - 07:57 PM.
H18m
p16
Venture15
Posted : May 10, 2012 1:55 pm
Been there done that. Likely the tramp will have to be loosened, not likely removed. You need to take the outer bolt off the hull, then the end cap off and then the lug out of the cross bar. Then replace the captive nut and put it all back together.
YOU MUST USE ANTI SEIZE or it will be all bad. HTH, Richard.
Posted : May 11, 2012 2:14 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
