81 Supercat 20 Tall Rig
http://plattsburgh.en.craigslist.org/boa/4454094029.html
Already have a 22. But it looks like a good deal !
The newer tall rig masts are boomless, from what I've seen/know. That mast has a gooseneck for a boom.
If someone does get it be sure to check the bow tangs. The older one had plywood bulkheads and rot over 30 years, needing to be replaced. I know because I've done it to 2 SC20's!
http://www.thebeachcats.com/pictures/?g2_itemId=88707 . Here's a write up of replacing the bulkheads. You can get new bulkheads and the replacement caps from Aquarius plus all the advice you'll ever need.
If you can wiggle the tang it probably needs to be replaced
Just found a video I made of what the loose tangs looked like on the SC20 I just finished redoing
I guess I need to show it off now 🙂 converted to solid beams, self tacking jib, custom 12ft long SNU, and a brand new set of Technora sails from Smyth Sails
