what is "Soft Hull"?
I see this quoted frequently. Does this refer to a delamination of the glass composite, or some other fiberglass issue? I am assuming that there is little to no wood backing or forming in these modern (post 70's) hulls, hence it would likely be a resin / cloth disassociation issue?
Thank you for the input.
That is pretty unusual, usually you will see crazing, cracking and leaking before it gets that soft. Unless someone painted over it. Soft spots are insidious in the foam laminate hulls because if the core and backing are delammed, you won't see anything on the hull itself. Until of course you put your hand through it...
1981 Nacra 5.2
Best example of how to identify it I know of.
http://www.youtube.com/watch?v=dL33jMcV4oM
Dustin
Magna, UT
Prindle 18
Quarath wrote: Best example of how to identify it I know of.
Thank you
That explains it perfectly. I guess these were not vacuum formed over the foam cores or the cores were hydrophobic. I get it now and understand how to find it.
